Trim Problems
Cloak
I have an older Tide Craft bass boat with a Johnson 115 on it and the throttle control is Evinrude...............for some reason the trim does'nt work right. In one of the back compartments, the trim connects to a solenoid that looks exactly like a FORD starter solenoid.
Does anybody have a diagram showing which wires go where on the solenoid?
Any help is greatly appreciated.
Thanx
Cloak
Re: Trim Problems
if i jump one of the studs, the motor trims down ...........if i jump another stud, it trims up automatically
acke61
Re: Trim Problems
if your hitting a button on the throttle and its not working....either some wiring is bad...the switch is bad...or that solenoid is bad...if you jump the solenoid and it works then its one of those 3...
Cloak
Re: Trim Problems
ok......figured it out.................traced the wires from the throttle tilt and the front trolling motor hook up tilt controls and ran new wiring altogether............took me alittle while but thank god I can use a Fluke.
Thanks for your inout anyway acke
