Towards the end of last season I had issues with my trim pump, specifically, the wiring between the trim pump and the solenoids. I discovered that when my trim pump wasn't working, if I played with the connection between the trim pump and the solenoids I could get it to work.
I tried cleaning the connectors with an electrical connector cleaning spray I got at radio shack, but it didn't help. I can't get a wire brush on the connections due to the way the plug is designed. Does anyone know if I can get new plugs to match OEM? Should I just get some universal plugs and splice them in? Given that there wasn't a lot of slack in the wiring, I'd probably have to splice in another few inches of wire. Are there any special type of marine plugs, or will type of plugs be ok?
