liquidlew
Thread starter- Joined
- Feb 14, 2008
- 304
Found out I did have a bad down solenoid on the trim pump so I replaced both up and down solenoids, re-cleaned everything up real real good and put it all back together today. Good news is that it works. Bad news is that it still takes a couple of seconds after hitting the switch for it to finally kick in, it makes noise and hesitates before it finally goes full giddyup. After getting it going it runs ok but if it sits for a few minutes it does it again. Should I suspect the motor? Someone earlier said I might have "tight rams". How do I know if that is the case and how do I fix that?
