GSPLures
- Joined
- Sep 3, 2019
- 564
How are you all doing, when it comes to wiring the trim pump up I am ignorant (in this case ignorance is NOT bliss
I am going to explain the issues as thoroughly as I can so I apologize for the long post. I am working on a mercruiser 140 with a mc-1 outdrive
I believe I have a Frankenstein setup from the previous owner. I know the bellhousing assembly has been changed to a different style it has the junk yard yellow paint pen on it saying it was for a 165, I also believe it was for a newer setup. From what I have read my bellhousing should of had the nails holding it together but this one has the bolts under the trim limit switches that require the special tool to take apart.
When I bought the boat the drive was off and there were some cut wires and some not hooked up. I do not believe the trim wires were hooked up (it was a while ago, I gutted the boat and rebuilt).
There are the 4 wires coming through the transom assembly which 2 are cut and the others have the male bullet connections.
There are 2 wires coming from the trim sender on the top of the inner transom plate. Which also have the male bullet connections.
I have looked at all the schematics in the mercruiser manual and I do not see anything about the gimbal mounted sensors although a parts blowout on mercruiserparts shows parts numbers for a gimbal with and without the senders.
Which wires do I hook up and where?
Not sure if some of the wires are not used which is why they were cut or what is going on
I appreciate your help
