Trim pump
brendanstl
Anyone know where I can find a cap for the trim pump reservoir? This is what my pump looks like. I think I need a new cap because when I run the drive up and down it is leaking through the pin hole in the cap.
z1nonlyone
Re: Trim pump
Its supposed to have the pin hole to vent the tank. Check your fluid level.
brendanstl
Re: Trim pump
I understand that but isn't there supposed to be a diaphram under the cap to keep condensation from entering the reservoir? I have read a few threads where people had mentioned it was supposed to be there and it looks as if the PO had lost the original cap and just used a generic cap and poked a hole in it. I also suspect that the reservoir is overfilled as well due to his poor maintenance.
Re: Trim pump
Ayuh,... I think Mercruiser has an updated cap for those....
brendanstl
Re: Trim pump
I ave searched the net everywhere for those and cannot find them, hopefully someone will come along with a part number or a link.
havasuboatman
Ensign
Re: Trim pump
mercruiserparts.com
36-865448A01
How hard did you look? I found it in 38 seconds.
When you fill the drive resivoir the drive needs to be fully down and only fill it to the mark embossed on the resivoir.
brendanstl
Re: Trim pump
mercruiserparts.com
36-865448A01
Like I said I searched for a while....... Wasn't aware of mercruiserpats.com and now that I know I will have another option for searching parts. Thanks Hava and Bomar.
