libellav15
Thread starter- Joined
- Jul 3, 2010
- 177
Hi again
I have posted a questione re oil up in the armature of my trim motor.
Any advice on that would be greatly appreciated.
As a follow-on issue. The trim pump is obviously not working until i can get it rebuilt/serviced etc.
My question is - if i reinstall the pump, and all hydraulic cables, then bleed the sytem by lifting the leg by hand for a few cycles, is it then concievable/safe to then re-tighten the fill screw and vent screw having set the leg in a useable position.
I would rather do this than strap the leg down, (which i know would be stupid but we only use it on a river at 4 mph) because presumably the leg would be able to come up if we did happen to hit something - due to the built in safety feature of the tilt cylinders.
Again any input would be appreciated guys.
Cheers
Adam
Cheers
Adam
