Trim Question
2 Horse
1996 Alpha Drive
Trim Down Works
Trim Up NOT Working
Trailer Up Works
Is it a bad solenoid or trim limit switch ?
frank246
Re: Trim Question
1996 Alpha Drive
Trim Down Works
Trim Up NOT Working
Trailer Up Works
The trailer switch overrules the trim limmit switch and uses the same up-solenoid.
The trim limmit switch or wiring to it couses the problem your dealing with.
Good luck!
MrRags
Re: Trim Question
Good luck!
Did you ever get your problem figured out as i am having the same issues? I replaced the solenoids to no avail so i am about to look into the trim limit switch but would like to make sure before i spend more money and time tearing everything apart.
achris
More fish than mountain goat
Re: Trim Question
As this thread is 2 years old I suggest you start your own... If you do that, I will give you some advice on pinpointing the problem.
MrRags
Re: Trim Question
OK i will start a new thread right now as i need help quickly thanks.
