I got a Mercury motor (1989 150HP) that didn't have the trim sender on it where the two screws are on the left side of the tilt and trim unit bracket.
I bought a trim sender used, but does the tab that goes in the slot of the shaft rotate in the sender body, or is the whole plastic part supposed to rotate under the mounting screw heads? In other words, should I be able to grasp the tab, holding the sending unit body, and turn it?
The mounting screws go through the two ears on the sender body, and they're slotted. Does the whole body of the sender unit rotate under the mounting screws (which would mean not to tighten them all the way down to allow for movement)?
thanks
thanks
