inside0ut
- Joined
- Sep 3, 2013
- 67
I actually posted this in the wrong forum, figured I post it in the right one!
Hello all-
I have been troubleshooting my trim assembly. I have a wellcraft 210 classic with the 350 and my trim wont move when I engage the switches on the throttle. I used the troubleshooting guide I found online from a helpful member here ( this is it) and when I jump the connections it is fine. What doesn't work is when I do the solenoid test, the solenoid clicks, but nothing happens. All other test come out fine (110 amp fuse, 10 amp fuse, and jumper the main connections). Could this just be bad up and down solenoids? I always thought that if the solenoid clicks then the contactor is closing so it should engage power...i may be wrong tho.
Any help is appreciated!
Also, if it is the solenoids that are bad, does anyone have a part # so I can make sure to order the right one?
Hello all-
