Four86Winns
- Joined
- May 11, 2007
- 28
I have an Alpha I with the standard controls. I can't trim up. Down works but not up. However, the trailer button works fine, which leads me to believe that its an electrical problem, not hydraulic. The trim up switch does work, however, when the sterndrive is in the upper range, like in the trailer position. But I can't use it to adjust trim while underway. Just got the boat back, didn't have this problem before winter storage. My mechanic replaced the bellows and shift cable, could he have inadvertantly screwed something up in the process that is causing this. After the bill I'd rather figure this out myself because it sounds pretty simple. Any ideas, thanks?
