QC
- Joined
- Mar 22, 2005
- 22,783
Re: Trim tabs- why no factory option or standard?
A lot of good info here mixed in with some misconceptions. This whole thing about "need"ing tabs is rather silly. Tabs are a tool, if you don't want more ways to manipulate your hull, then OK, good on ya . . . But, whether a hull is 50 years old or brand new, it is a compromise. No design does everything well, but tabs will extend the "good" range of performance. Helm adjustable tabs will offer even more flexibility.
On the heavier engine thing, yes, most boats have more power today than a similar boat 20, 30 or 50 years ago. However, power density (power to weight/size ratios) has improved so effectively engines have actually gotten lighter. There are exceptions, but small blocks do the work of big blocks these days and there were no 300 bhp OBs 50 years ago, so you could argue that there were no 500 lb options for a similar output motor and drive package back then . . .
Also, many, many older boats are straight inboards, they plane off well with little to no bowrise because weight is more forward, and the angle of the dangle is good for hole shot. They are all slower and less efficient than the same with a trimmable drive system and the same power. This is true to the point of not even being debatable . . .
