trim tilt help
busatom
I have a 454 mag with merc alpha 1 '87 Baja 240 Sport. The outdrive will go down with the trim down button, but the trim up does not work. luckily there is a trailer button, that I can push in to raise the outdrive when needed. is this probably a short somewhere? How would I check? Thanks,
Tom
Don S
Re: trim tilt help
Chances are, you have either a bad trim limit switch on the gimbal ring, or the wires have rotted off. Happens all the time.
Go to the "Adults Only" sticky at the top of the fourm, locate the Merc service manual link and download #6 manual. The troubleshooting section covers your problem in detail.
busatom
Re: trim tilt help
Thanks DOn, your help is ALWAYS most valuable on this site! It is truly appreciated!
Tom
snoski
Re: trim tilt help
I had the same problem and found the muscrats ate through the wire Don S is talking about...
