trolling motor mounting question
willyrocket
I have an old starcraft aluminum that I am redoing. I am cutting the front deck off and fabbing up a casting deck. I havent cut the front off yet. I am wondering how much coaming to leave in the front to mount a foot controlled motor. I dont have a motor yet, I know the newer ones take up a little less space (small footprint). If I come across a good used one, I will probably nab it up, so I will go on the basis that it will be of the older style mounts. I guess question might be a little confusing, I can post pics if need be. Right now, I have about 17 inches left of the front. How wide are the mounts also? All sizes can be approximate.......
JB
Re: trolling motor mounting question
Can't visualize what you are working on, Willy. Pix would help a lot.
Silvertip
Honorary Supreme Mariner
MotorGuide electric steer and MinnKota power drives have the smallest footprint. They are roughly 8 inches wide and about 12 - 14 inches long.
tashasdaddy
i would get the motor and make sure you set up correctly. hate to do things twice.
Barnacle_Bill
Don't forget to consider your wiring while you have things apart. I would run #6 up there to cover any motor you may want to use.
mars bar
I would have to agree to tashasdaddy, I'd get a motor first then chop:)
willyrocket
pics..........
willyrocket
Will probably go even bigger than 6. I love overkill............. Long ways to go before wiring. AET for the Coast Guard for 11 years, so Im gonna do some bad mofo wiring on her!!!!!!!!!
willyrocket
Was trying to get an idea of the footprint. I still have some time before I cut the deck. Just tryin to plan ahead a little. Maybe momma will let me get an income tax return present in the form of a trolling motor!!!!!!!!!! Still contemplating what kind of bracing I am gonna do up front for it also. once the deck is cut, I will continue the coaming up to the front........
Shizzy
Ensign
one more thing I just remembered about waiting till you have the motor Is that many times I plan out project, I change plans once I have my hands on it. I get in to the project and decide on the fly that all my planing and thinking isnt right. Something always needs to be bigger, smaller or placed in a different spot.
SKEETR
This is the way my boat was set up. Looks a little unusual but seems to work just fine. I do like how it is clear of the anchor line. The mounting plate appears to be 1/4" and there is a spacer underneath. 3 bolts hold it down two run directly thru the frame. Just thought I'd throw it out there for an optional idea.kota mount 2.jpg
willyrocket
You guys leave me no choice but to tell the boss I need a motor to make any progress. So I can tell her that you guys said I NEED it now!!!!!!!!!!!!!
tashasdaddy
you are very correct. and i really recommend, the wireless remote control motors. i will never go back to a foot control motor.
