I have a slightly older (1997 or 1998 model) bow mounted Motorguide foot controlled trolling motor that has a big dent in it around the top part of the shaft and it's almost impossiable to turn it in either direction now. It's mounted in the Gatormount that came with it and I was wanting to know what is needed to switch to a newer hand controlled model and still use the Gator mount that is already mounted. Also any problem with using a MinnKota model with the mount. This is on a pontoon and the foot controll just got in the way so I'm going to use it as a backup if a hand controlled model will work. I'm askig this because I can get a good deal on an hand controlled motot but it just has a standard mount.<br /><br />Thanks
