DTM
Thread starter- Joined
- Jul 20, 2008
- 38
I have an alpha 1 mr mercruiser, I changed the water pump. I did that all right but reassembling was an issue. The instructions I printed off the internet are confusing. Here is the address I got them from
http://dolphinmarineservice.homestead.com/RepW.html
Step 28 says, turn the shift shaft with brass piece clockwise and continue to apply pressure to the prop counter clockwise, when it stops it must be facing foward (towards the bow). Then it says, if the point of brass shift arm is not pointing forward (when it turned), lift it and change its position on the splines. I underlined the parts of the instructions that I don't get.
Everything pulled up nicely but I could not get it in reverse at all. Please help
