trouble going into reverse
PowerAddict
Just this past week I have been having problems getting into reverse, as in, it will go in like 5% of the time. It goes into forward no problem every time. I presume I have to adjust the shift cables somehow? What do I need to do?
jerryjerry05
Re: trouble going into reverse
How old is the shift cable? You probably need to replace it.Jerry
Don S
Shift cables don't suddenly go out of adjustment. They do wear out. The inner core wire wears a groove in the outer sheath creating a lot of extra slop in the cable. Replacement is the only cure.
PowerAddict
darn. So its for sure the cables then?
