kennyboater
Thread starter- Joined
- Mar 11, 2008
- 95
i am trying to change the impeller and gaskets on water pump on 1984 25hp merc XD. I am using a SELCO manual.
it says to:
1. tilt the motor until it locks in the upright position (Done)
2. shift the motor into the forward gear (done)
3. "Remove the shift lever coupler located in the bottom cowling behind the carbuertor" (not done, I think i know what the coupler is, but i can not get it off while in forward... just to make sure, is the coupler the piece that is around a ball ? if so, how do i get it off? (there are no pictures of this)
4. remove 4 bolts holding lower unit on, (Done)
5. "ease the lower unit from the intermediate housing (not done, i can not get it to pull off and i do not want to damage anything...it seperates about 1/5 of an inch, but will not pull off anymore...)
Please help, stuck on these to points: the shift lever coupler, and pulling the lower unit off.
thanks
it says to:
thanks
