I am adding another bilge pump because my 87 bayliner capri leaks a little. The current bilge pump sits up a inch or so and has its own internal float switch, so it does not catch the water that is below that pump. There is a place to put another pump in to collect that water. My question is can I run the second pump to the current bilge output hose with a three way splitter? Or do I have to install a shut off valve in line between the original pump and splitter to prevent it spraying out the original pump when the second pump is turned on? Thanks
