I just replaced my VRO pump. Evinrude 200 HP, 1996. It cost a fortune.
Now the worries. Can a new VRO pump be damaged by pumping the oil bulb when the oil line is connected to the VRO Pump? I was told by the shop to be sure to pump the bulb really hard to remove all air from the line, but I'm thinking now that I should've had the line disconnected. No big deal or a possible problem?
Secondly, my electric tilt works great going up, but when I go back down it is inconsistent. Sometimes the switch seems to be defective, or, perhaps, the mounting is binding up. Always perfect going up, but "hit and miss" going back down. I have to fiddle with the switch, or so it seems. Any ideas on what I should check or look for? It doesn't seem like it could be a relay, unless a bad relay would react intermittently like that. A ground wire? Or, maybe it is just binding a bit; it's heavy enough.
Thanks in advance.
Thanks in advance.
