Re: Unanswered questions.... I'll give it one more try.
Hey buddy nice looking boat you got there! Given all the work you've done, if the transom does need doing I would seriously consider doing it from the outside using something like seacast.
There's 2 ways of using seacast, removing the wood from between the 2 skins from the top like others have said or have a look at how they do the mako transoms, they cut the outside skin then remove the wood then repair and reuse the old outer skin using the seacast pour to bond the old skin back in.
IF the stringers and floor don't need to be done you could leave them untouched using both these methods, but you should check the stringers and floor before you do anything, my floor felt solid almost all over but most of it turned out to be wet and my stringers even looked solid and felt dry after cutting into them for the transom replacement but when I drilled into them they were rotten at the very bottom.
Not to sure how you get that cap off, there are a few designs the pro's will let you know, they may need a picture of the join from the inside to tell. They'll be able to advise if it's safe to use or not too, I think if it rotten at all don't use it but if it's only wet and there's no flex in the transom you MIGHT get away with it for a season but I don't like the idea given the size of the beast hanging off the back.
