Under Construction: Bateau.com TW28 Stretched
Status
Not open for further replies.
you could have used an 18" or 24" 1/4" drill bit extension and a set of leather gloves (acts as a bearing on the drill bit extension).
its rube goldberg, however may have allowed you to reach the bottom without having your head stuck in the keel.
KnottyBuoyz
I have one of those here somewhere. The operative word there was 'somewhere'. When I get this job done, Walla! There it'll be right in front of me! *sigh*
KnottyBuoyz
Working smaller sections that I can handle easier. Hope is to spend more time building than fixing up screw ups! We'll see how it works. So far so good.
Just one 4' section done along the starboard side. Getting hot today so called it quits at 11:00 when the temp in the shed hit 33C. I'll try to get 3 x 4' sections done tomorrow. I did do the back end of the keel in smaller sections and it worked out fine.
Web log updated: http://she-kon.blogspot.ca/2015/07/slow-steady.html
KnottyBuoyz
Another 12' section of the keel done. Going to try to wrap up this first layer in the box keel nonsense in a couple of days.
Next step will be bottom on the port side. I have to order some more glass for the starboard side.
Standby....
KnottyBuoyz
Removed the uprights & cross bars from the rolling frame. Thank The Maker they're out of the way. It'll be pleasant 'Not' smashing my head on them constantly!
Birds Eye View
Port side bottom panel will get glassed next. Just have to go round with the sander and dress up some fabric edges & shiny spots.
It'll be a 'Big Pour'. IIRC the time we did the outside bottom it took 11 hrs & 3 1/2 gallons of epoxy and that was with a helper mixing goop.
Standby...
KnottyBuoyz
First foray into cutting metal with woodworking tools! Laid out and cut the parts for the skeg.
Circular saw worked amazingly well but it killed my jig saw! :upset:
Too friggin' hot to do any epoxy work. Hit 102 yesterday with the humidex. I was out of the shed by 10:30. Had a decent breeze so worked with my new lil' welder on some mods to the dingy trailer.
Lots of pics and a 'non-sanding' video on today's web log update: http://she-kon.blogspot.ca/2015/07/the-skeg.html
KnottyBuoyz
Bit of welding this morning to finish up temporary bunks on my dingy trailer then started to lay out the thrust plate for the Python Drive.
Not much to look at right now. I have to get a 120 mm hole saw. That should be spendy! :facepalm: Couple of places I think I'll be able to use it later though. The clouds opened up so I had to call it quits.
Yesterday I beveled the edges of the skeg parts that'll get welded. Don't know if I did it right but it's done. I did it with my router.
Had good intentions of getting some fiberglassing done today but my back is kicking up a fuss. Dunno why that is. It's been really good for a couple of months now. Gettin' old suks! :cold:
when using power tools on aluminum, pick yourself up some stick wax to wax the blades. they will last longer and prevent the aluminum from galling.
Status
