upgrading the ignition in my 4.3 Mercruiser
harcos
I am upgrading the ignition in my 4.3 merc, its in a 1996 Larson.
I am having a hard time finding a wiring diagram for it. I need to what the wires off the original ignition module plug do. The wires in the plug are in a single row and are as follows.
1) Grey, 2) Black, 3) Purple, 4) White/Red stripe, 5) White/Green stripe, 6) Purple/White stripe, the 8th slot isn't used and 9) is White/Green stripe
If anyone knows or could give me a link to a correct wiring diagram I would much appreciate it.
Serial numbers are best when asking about a motor
Being a 96 and listing Pur/Wht wire it should have a TBV ignition. The pic shows the TBV module and knock module. You probably don't have the knock moduleTB5 Wiring 1.jpg
harcos
Being a 96 and listing Pur/Wht wire it should have a TBV ignition. The pic shows the TBV module and knock module. You probably don't have the knock moduleView attachment 360139
@alldodge, thank you very much for the schematic, unfortunately it isn't the same as mine. The wires from my module are clean and easy to tell the colour and I don't have a tan or a yellow wire. What serial number should I be posting? The one from the boat or the one off the engine? Actually I will add both this evening.
You have a TBV ignition module, it's just the older style which uses a different connector. Its no longer made and if it needs to be replaced then there is a kit to change over to new design. The pic below is showing the newer design but where the wires go is the same except the Tan/Blue is not there
whats wrong with the original TBV?
harcos
Thanks for the info alldodge. I got the new setup wired in and she seems to run pretty good.
