Evil Eagle
Thread starter- Joined
- Mar 26, 2012
- 23
Hey guys, I am buttoning up my lower unit and I am stuck on something. I have the factory manual in PDF, as well as the seloc in print. I replaced the short yoke and and putting new seals etc in. I am putting the upper driveshaft back together and I am stuck on something. I had originally thought I was going to have do the rolling torque on this, but my set up does have the small spacer in it. Am I reading this correct that WITH the small spacer you torque the nut to 70-80 ft lb and you're done, but if you DO NOT have the small spacer this is when you do the rolling torque with a beam torque wrench reading in lbs? Thanks guys.
