holorinhal
Thread starter- Joined
- May 26, 2009
- 119
I have a question about the upper shift shaft. I have the Merc 260 and I am replacing the shift cable. The arm at the top of the shaft was real loose but I tightend the set screw and it tightened back up, however the little roller is chewed up a little so I am going to replace it. The shaft its self has some up and down movement and some movement side to side. is this suppose to be the case? Is there suppose to be up and down movement? I asume that the side to side could be from worn bushings. Does the shaft itself ever wear, it looks to be in good shape? The shaft is the most expensive part so if it does not need replacing I would rather not. i will replace the arm, bushings seals and washers...H
