Re: using automotive oil for a 4.3 stern drive
C class oils have little significance when discussing gasoline engines. API C designates Commercial class or Compression ignition diesel engine oils. S class oils are API designated for Service class or Spark ignition gasoline engines. The Mercruisers being discussed here are gasoline engines.<br /><br />When discussing diesels (Mercruiser does have diesel engines), CF-2 class oils are not excluded from being multigrade oils. They are not always two stroke single grade oils. The Mercury 25W-40 is an example of a multigrade CF-2.<br /><br />The newer CI-4 class does not make CF-2 oils obsolete, nor does it supercede CF-2. CF and CF-2 are
current specifications with their own unique applications. CF has superceded CD and CE for diesels using fuels that contain high sulfur content. CF-2 has superceded CD-II where diesel ring and cylinder scuffing is a factor. CF-4 is another different classification. CI-4 oils do not necessarily meet the requirements of CF or CF-2. The CF classifications will be listed separately on the container.<br /><br />The 25W-40 is not a single grade 40 oil. It is a combination of multiple grade oils and different base stocks.<br /><br />The API, along with ASTM, SAE, etc. have established industry standards for testing and classifying oil viscosity that go beyond cold crank and flow tests. The Mercury oil is listed as a 25W-40 because it meets those 25W-40 standards. <br /><br />It is unlikely that a 40W oil would pass 20W flow testing or meet the APIs requirements for a 20W viscosity, or that multigrade 15W-30s are CF-2 30Ws.<br /><br /><br />
Originally posted by DHPMARINE:<br /><br />Oildoc,what happens to the oil sitting for a while?
Quality marine oils contain soluble additives that include corrosion inhibitors, antioxidants, and suspenders. The suspension additives keep the inhibitors suspended throughout the oil. They will remain suspended for extremely long periods of time. It would be important to change the oil before storage to remove the acids and contaminates from the engine, which cause corrosion and oxidation.
