V6 150.......... Problem peeing
ronnieboy
Re: V6 150.......... Problem peeing
capt, you need a bigger gauge than 15 #, my 88 150 runs 2 to 3 # at idle, poppet opens at 8# wot pressure is 24 pounds! thats wot, @ 5800 rpm @ 61 mph. Ranger 374vee. hope this helps, ron
gregtobin
Would you mind summarizing this thread by listing what you checked and describing how you fixed the problem?
I think it would help many of us!
Thanks!
CARLOS
Please...as gregtobin requested...
Could you please summarize a brief history how you solved your case by step...
I have a 2.5L 200HP 1994 and have experienced the same problem, infact I´ve changed the impeller and T´stat but the pee hole continue intermittent...
But no everheating, my engine is working good...That´s curious...
I´ve been using my engine for many hours with pee hole intermitent...
Regards
Carlos
Venezuela
Capt. Crunch
Gregtobin and Carlos, great idea. I'll edit the first post to include a summary, so it will be easier for everybody. I'm just going to wait until I get the last problem worked out.
I still can't find what is causing the overflow of water from my exhaust relief ports below the cowl. The only info I can find on the net was from somebody with the same problem on a Johnson/Evinrude. They told him he must have an issue with water leaking out of his water pump/water tube (missing grommet at end of tube in pump) causing the exhaust housing to fill entirely with water.
I may be pulling the lower off again tonight and hooking up directly to the hose again tomorrow...
Oh, and fishingdan is correct. Both our posts relate to the exact same thing. We even have pics of our motors in each others posts. I'll link to it in the summary too.
Dennis
