Fairly new to this forum, but have gotten some great advice and learned a lot from reading the posts. I really appreciate all of the assistance and have benefitted greatly from everyone's experience here.
I just finished a 4 week long saga resolving troubles from sour fuel in my boat. Replaced many parts - hp fuel pump, o-rings, fuel lines, fuel pressure regulator and thermostats (while I was at it).
Was anxious to get it out on the water today to test it out. Had run in the driveway several times and all seemed right with the world. Of course ,the acid test was going to full throttle. Well launched this morning and it fired right up. Once I got past the no-wake zone i nailed it and it was perfect. no misses, no hesitation, great acceleration. Got through the bayou and the lake was fairly choppy, couldn't run very fast so we were going to head to a structure to fish a while. Not 10 minutes later, I get the continuous beep alarm indicating an overheating condition. Brought it back to idle and looked at the telltale which was strong. Put my hand on it and the water was very hot. Looked at the water pressure gauge and it was barely registering.
Shut it down after about a minute and dropped anchor. Pulled the engine cover and let it cool for a while. After about 15-20 minutes, ran back through the lake to the bayou deciding that it might be better to run fairly quickly as opposed to slow, I kept an eye on the water pressure gauge and listened for the alarm. Planned to shut her down again once in protected water. Had abolut 8-10 pounds of pressure on the gauge. Got to the bayou and after another cool down period ran the remaining 5 minutes to the launch.
Every time I restarted, she cranked instantly. With low water pressure, I'm sure the impeller's out, but i don't understand why I had such a good telltale stream. My engine has been notorious for having a weak telltale, particularly at idle. If the impeller is bad, can I still get a strong telltale?
I've already picked up an impeller kit and plan on changing it out this week, but could this have anything to do with the new thermostats i installed? Purchased the stainless steel versions because the others had gotten so coroded. Other than parts of them being stainless, they looked identicle to the originals. Also replaced the rubber grommets (seals?) that wrap around them. Could the poppit (sp?) valve be acting up? Never had an overheating problem with this engine before this. Impeller was about 3 years old and thee boat hadn't been run in a while (hence the sour fuel issues that started all of this).
Anyone have any thoughts on this?
Thanks.
Jim C.
Thanks.
Jim C.
