very big screw up
btctboater
i didn't pull plug,this fall.just uncovered boat and water up to valve covers.am i screwed or can i drain and save???please help.
kenny nunez
The best advice I can give is to call your insurance man. I am pretty sure it is a total loss.
tpenfield
Drain the boat and examine the engine . . .you are in for a bit of work and expense, but no way to tell if it is savable without an first hand look.
tpenfield
most of your issues may be electrical, if the engine did not get any water inside. How is the boat's structure? any freeze damage, water saturation, etc?
Redrig
The engine may very well survive , but its the transom / motor mounts / under the deck that would be the bigger concern.
Good chance all of the wood will be rotten very shorty , and your boat probably weighs an extra thousand pounds from water getting inside of everything .
Everything electrical needs to be replaced. Hull most likely has permanent water in areas that water should never be
drive will need to come off as bellows are now full of water. Depending on how long it sat, you may need new u-joints and shaft
As Kenny stated, call your insurance company
