volt meter
renny1
hi all
can someone advise me where to wire the volt meter to??? does it connect straight on the battery or through the engine
thanks in advance
115hp 1982 blueband 6cyl
Laddies
Banned
Re: volt meter
On the frount of your control box there is a plug in for a tach, use a voltmeter and will find a + and - plug the positive turns on and off with the ign switch thats where I hook them up
Silvertip
Honorary Supreme Mariner
Re: volt meter
There is a far easier place to connect the voltmeter. Every one of your other gauges except the speedometer and water pressure (if you have one)has a POS and NEG terminal on it. The gauges get power only when the key is on. Connect the POS and NEG terminal on the voltmeter to the POS and NEG terminal on any of those gauges.
renny1
Re: volt meter
thanks laddies and silvertip that seems an easy task , at last an easy job on a boat
