Navigator_Victory
Thread starter- Joined
- Apr 3, 2011
- 284
I have printed out the information for fuel system testing..http://forums.iboats.com/showthread.php?t=283269....guess I am hoping there is a shortcut to to all of the testing....... if I say what it is doing ???
Ran perfect for about two hours started chugging and then no WOT.....changed fuel filter and ran perfect again for about two hours then same thing chug chug at WOT....ran fine at idle each time and I could get up to about 2500-3000RPM....no big deal bad gas from Marina change filter.....one or two hours same thing chug chug....ok this is getting old but boat has sat for at least 5 months so once again I change the filter but,,,,,,this time it will not hit WOT.....does not die but, acts like it wants to.. also note it surges if I mess with the throttle IE gas it then pull back or vice versa...... I pulled the fuel filter and I noticed it is only half full of fuel wheras the other times it was full.......so I am thinking :facepalm: can I short cut all the fuel system test and go straight to the problem......or at least I am thinking it is the fuel pump or the pickup tube is clogged...???......then again I guess I should go through all the steps just to make sure before I spend $$$$ on something I do not need.....
Well ok I guess I just wanted a place to vent......but,,,,,I will probably start at the pickup tube and see what I find......that is if I can find the pickup tube
