Volvo bearing help!
Kng15012
I have a 1993 welcraft excel. The motor is a 430 v6 ( according to the flame arrester). The drive says sp. I have bearing noise and my local mechanic said its the bearing in the housing of the flywheel. So now I can't seem to locate the right parts for my motor and drive to do the repair.
Any help would be great!
jackd1023
Re: Volvo bearing help!
Sounds like the Gimbal bearing, in the transom assembly. If you are able to get the serial number I am sure someone can get you the part number.
Kng15012
The mechanic wrote down these part numbers. (He said he couldn't locate the parts, that I had to find them)
3851019
958859
(2) 914533
914462
958860
Kng15012
I have found these parts on the volvo site. But my issue is there is a 430a or a 430b. Which one do I need?
jackd1023
Do you have the serial number off of the drive? That will lead you in the right direction
Kng15012
Where would the serial be located? I'm new to volvo. Ill post it as soon as I get home
billbayliner
First off if it is a SP then you have a model SP-C out drive as per the 1993 year
I am guessing you had water intrusion in your drive bellow?
First there are no gimbal bearings in the AQ series drives and with the part numbers he is giving he is referring to your PDS bearings.
NOW....... There is a way to tell if water intrusion made it past the seals that protect against water incorporating the transom shield / bell housing.
On the fork that goes in the primary drive shaft there will be rust from the water in the bellow. If the seal did its job there will be a distinct line where the rust stops and further on it is not rusted. This indicates the seal prevent water from getting into the PDS bearings.
U-joints with water in the bellow will deteriorate quick and will grind like heck.
Ok here are some number for you:
3851019 .............
958859
(2) 914533
914462
958860
958860 seal is: Metric Oil Shaft Seal 35 x 62 x 07 35x62x7 Double Lip
958859:Metric Oil Shaft Seal 35 x 55 x 07 35x55x7 Double Lip
3851019 Bearing (single for DP-C1 and up): PDS single will be a 6206 SKF sealed
PDS double bearing assemblies will be a 6206 bearing and 6007 open bearings (or a sealed bearing with the seals removed).
Hope this helps. U/J's / Spiders for that drive can be found on Ebay for lower than the $162 Volvo wants and the $119 Sierra wants.
ONE NOTE THOUGH: I cannot find my Flywheel / PDS assembly exploded view for the SP/ DP-C drive and for some reason I thought there was a change in the DP-C1 pds assembly. I know they went to sealed bearing in the C1. Double check to make sure your mechanic is not referring to the C1 and is looking at the C PDS assembly.
Also, no need to remove engine for this procedure like many want to do.
I will try and confirm the numbers for the C drive PDS bearing
UPDATE: I just checked some number on the SP-C (430A)
For: 430A, 431A
Figure # Description Part # Qty*
Req. Note Unit
Price Availability
1 Flywheel Housing 841967 1 $1040.90 Add to Cart
2 Spring Washer 942336 6 $0.14 Add to Cart
3 Screw 941939 6 $10.11 Add to Cart
4 Spindle 853809 1 SN-4100133205 $467.43 Add to Cart
5 Sealing Ring 958860 2 $25.70 Add to Cart
6 Ball Bearing 11013 1 $20.16 Add to Cart
7 Ball Bearing 181105 1 $24.83 Add to Cart
8 Snap Ring 914533 3 $4.19 Add to Cart
9 Snap Ring 914462 1 $0.76 Add to Cart
10 Clamping Ring Kit 854316
Replaced by
873048
813964
191844
813967
806624 1
$77.38
$152.68
$8.47
$75.30
$15.60 Add to Cart
11 • Rubber Ring 813967 2 $75.30 Add to Cart
12 • Hexagon Screw 191844 6 $8.47 Add to Cart
13 • Striker Plate 806624 3 $15.60 Add to Cart
14 • Spacer Ring 813964 1 $152.68 Add to Cart
15 Lubricating Nipple 914167 1 $4.07 Add to Cart
16 Cover Plate 826448 1 SN-4100133205 $31.10 Add to Cart
17 Hexagon Screw 947224
Replaced by
969476 5
