So at the end of the 2010 season I ran the props through a sand bar. Kind of chunked the props a little bit bud had those fixed and it seemed the props would rub just a little bit. So we didn't think much of it and ran it all last season and when we winterized it we checked the oil in the drive and everything seems to be fine with no water inside. I would really just like to fix this, I ran a dial indicator on them and they are about .010 out on the ouside shaft and about the same on the inside shaft. I guess Im looking to see if there is a good way to straighten them out without pulling the lower unit off. I work at a place that straightens shafts with heat so i didn't know if that was a possibility or if that would just burn everything up. Or what the possiblilty of bending them back by hand would be. It doesn't seem to be a big problem yet but I don't want it to be later on either. I guess I'm looking for the best possible solution to my problem. Thanks again!
