Volvo penta 2008 leaking water on left side of engine
Zach32scott
Is there supposed to be a plug there? Also does it hurt the boat it’s been ran 2-3 times if a plug was needed and there wasn’t one ?
tpenfield
So, that 'hole' is on the exhaust manifold (right?). It looks kind of small to be a core plug, but the short answer is yes there should be something there, as it should not leak.
Check the other side manifold to see what the 'plug' may look like (usually the manifolds are symmetrical.
As to the damage to the engine . . . it sort of depends on how much water was leaking. Check to see if any of the rubber exhaust pipe couplers look like they may have melted or show other signs of deterioration.
2004 searay
i think what we are looking at is a expansion/core plug which is supposed ot be there. V/P maniolds do not have the fitting on the middle of the manifold like the mercs. that hole and core plug should be sealed.
BRICH1260
It`s kinda hard to tell from the picture but it looks like there is some sort of plug in there, perhaps broken off as I do not see a lot of threads visible. That is a manifold drain plug hole. Can you stick a finger up a ways into it? If it not leaking badly, you might be able to get through the rest of the season and make it an off season project.
Carver 2850
I'm a newbie here but that discolored line running through the "V" in the Volvo lettering isn't a crack, right?
Freeze damaged. Look for cracks in the block
