Volvo Penta 4.3 GL Loud Clunk When Put In Gear Fwd Or Rev
dtescher
Volvo Penta 4.3GL PLKD SX-C1 1.85 #4112030094. There's a hard clunk when shifting forward or reverse. I changed the gear oil and checked for metal shavings. None found. That didn't help the problem. Checked gap under large nut at the top
of upper gear housing, 0.12 reading. Checked cables for kinks etc. Adjusted shift cable per manual. Still no better. What else to check or should I just take it to a certified Volvo Penta shop?
Don S
Re: Volvo Penta 4.3 GL Loud Clunk When Put In Gear Fwd Or Rev
What's the idle rpm in neutral?
dtescher
600-650Rpm
Don S
Do you have SS prop and is the boat in or out of the water?
under large nut at the top of upper gear housing, 0.12 reading.
is that metric or inches?
dtescher
Aluminum prop. And it's out of the water.
Don S
Did you catch my second question above?
dtescher
Just saw it. That's inches.
Don S
If that's inches, you found your problem. You should have .002 to .010. The gap of 1 to 3 pieces of paper. You have an eighth of an inch. How or why I can't say without taking it apart and looking.
dtescher
Ok. Thanks Don S. I'll check it out. By the way, is it difficult to take upper gear housing apart to check it. What should I be looking for?
And how hard is it to re-shim? If that's what it needs.
dtescher
Correction!!! I just checked feeler gauge and it's 0.12mm. Sorry about the confusion.
Don S
Without the special tools, it's impossible.
Even with the special tools they can be a job to get shimmed right, and have the right gear pattern and preloads all at the same time.
I assume you have the OEM manual and have looked at the procedures?
Don S
Then you are fine,
dtescher
Yes, I have the manual. Good point. I wouldn't be able to do that. OK, but it still clunks. What to check next?
dtescher
Or just take it in?
Don S
Think your getting ahead of yourself, what's it sound like in the water when you shift.
dtescher
Clunk!!! And out of the water it's a loud CLANK!!! Can't tell if it's coming from upper or lower gear housing. And it's getting worse. No
water till I figure it out.
Don S
Get a shop tach, or a timing light with a tach built in and verify the idle speed.
How did you test the top nut gap? You had the upper off the lower didn't you and pushed up on the vertical shaft and down on the upper bearing didn't you?
How did the ujoints feel?
dtescher
I'll verify the idle. And, no I didn't have the upper off the lower. Just checked the nut with the feeler gauge from the top. I'm new to all this. So, I didn't know I was supposed to take the upper off the lower. And I haven't check the u-joints yet. Thanks Don S. As usual you are a wealth of information. I will try to get the upper off the lower and check the u-joints.
dtescher
Thanks Don S. The idle is all over the place. When it's at 600RPM it shifts perfectly(in water test). Anything above that and it clunks. Should I adjust the cable to verify a slight pre-load on the carb? And, how to best approach adjustment of throttle cable?
Levinz11
What does that mean? The idle is fluctuating on its own?
