ShamusCrowley
Thread starter- Joined
- May 17, 2010
- 18
Ok here is my problem I have not used my boat in two years . My brother in law used it for a half season but never had it winterized (Long Story). Well to add to problems the cover I had collapsed over the engine so rain could fall over top of engine maybe the carburator it has cleaner on top of carburator I just dont know. Here is the question:
What should I do before I even try to start engine?
a) Should I pull plugs and crank engine over in case water is in cylinders .If water entered Carburetor should I put some mystery oil in the cylinders through spark plug holes in case water got in cylinders. Then crank it over to work oil in .
Should I drain and change oil before or after I start it (in case engine is damaged from possible freezing)?
I know that if it frooze the oil should turn to a milky white color (I am praying it did not happen).
Any suggestions?
Any suggestions?
