volvo penta tilt motor problems
Dirty1
This is a aq 280. The tilt motor will only lift the outdrive a little bit before the motor stops. It seems that the motor is laboring perrty hard to get it that far. On the bench it works fine. I have just cleaned up the gears inside and regreesed everything. Is there some thing Im missing?
Dave
sqbtr
Re: volvo penta tilt motor problems
Couple of questions
How many wires are going to the motor?
Can you lift the drive by hand from where the tilt stops lifting?
Don S
Can you easily lift the drive by hand? Are the pivot pins binding?
bgc
Ensign
My 280 is doing this.
It will lift easily/smoothly by hand but not with the lift and sometimes the lift motor will not run. I tore down the motor only to have chunks of the brushes fall out. I took it to be reworked at a local electric motor repair facility.
