VP trim position sensor not working
drknute3
Need to replace the trim position sensor on my VP duoprop outdrive. Looks to be any easy swap with just 2 screws and 3 wires. Is there any tricks to changing these that I should be aware of? Will the replacement come with the wire splicers? Do they need to be water tight connections? Any special adjustments?
Thanks
Bill
drknute3
Re: VP trim position sensor not working
Thanks for the link. Looking at the manual it shows 2 wires from the sensor, but my unit has 3 wires. 2 black and 1 white?
Don S
Your new one will only have 2 wires.
drknute3
So which wire is left off when I wire in the new one? Will the new one come with wire splicers? If not, do the connections need to be water tight?
Thanks
Bill
