VRO (2) repair, strange item in pump. J 50hp-97
Leijon
While repairing my VRO2 pump, a broken air-pump-diaphragm, I found an O-ring on the piston in the fuel/oil compartment that looks strange.( Shown in picture).
Looking at the attached sketch there is no O-ring on the piston (part nr 13) and I am beginning to wonder if a previous owner has made changes to the pump.:confused:
This O-ring is identical with part nr 26. Coincidence?
Does anyone know if this O-ring should be on the piston or not?
Here in Sweden the boating season is almost about to end and I am eager to get back on the water.:cool:
Regards
Leijon
(Johnson 50hp -1997)
bugmanjr3351
Re: VRO (2) repair, strange item in pump. J 50hp-97
I have the same O-Ring in my pump. Same exact motor.
Leijon
Ok, thanks.
Whas it otherwise identical? Any diff?
I?m wondering about the rounded top as it can be pulled out of the piston a few mm.
/ Leijon
