VRO pump to Seirra fuel pump?
smoky joe
I have a 1997 40hp Evinrude the VRO has been disconnected for a while, I think the diaphram in the fuel side of pump might be leaking into my lower cyl causing my stumble at idle? Gonna replace the pump with a regular fuel pump from iboats but it does not give me a fuel pump for my year, do i just use the Sierra 18-7352 Fuel Pump it says its for: 25-55 HP 1976-89 ( non VRO )
and mine is a 97. Any help would be great!
petryshyn
Re: VRO pump to Seirra fuel pump?
did you do all the tests on the pump? especially the vacuum test on the vacuum motor diaphram. Until then I wouldn't change out the pump....
smoky joe
No havent tested the pump yet.....I enjoy throwing my hard earned cash into my money pit! Good suggestion Petryshyn I think I will, my buddy does have a gauge he bought that he tested on his fuel pump and turned out his pump was bad so i will borrow it. I wanted to replace all hoses with alcohol resistant ones, pump, and rebuild carbs as part of preventative maintanance soon anyway and hoping that would help my stumbling idle......so anyone know if that seirra pump is the one I need if it's bad or am I way off?
petryshyn
you of-course will have to mix your fuel if you down-grade the pump.
smoky joe
Oh ya I have been mixing 50/1 since I got the boat thats the reason I want to get a regular fuel pump and not the expensive VRO pump....anyone know if this is the correct pump before I order it? Searched through the forums couldent find any answers!
jonesg
Call iBoats customer service,
they'll make sure you order the right part, they give excellent service.
