wal mart hose ends
wargmc
hi
i have a e30ecrr i had a fuel leak at the motor where the gas line hooks up
went walmart bougfht new hose assembly
the tank end fits fine but motor end still leaks an is loose
is there two diff size hose ends
thank you
boobie
Re: wal mart hose ends
OMC only has one connector. Did you get the right hose assy ?? Or you may have a bad connector on the motor.
wargmc
yes sir it says omc johncon evinrude
wargmc
its made by attwood says hose fitting 8889lp6
ronward
try wigging it a little to see if it'll catch. ya might need to wiggle it while pushing to get it to seat
wargmc
yes sir i tried wigglin an pushing it on ... no deal
im gonna go to our evinrude shop morrow an buy oem fitting for both motor an hose end hope that will fix it
thanks for the help
nwcove
if you want a few more of those aftermarket " fits omc" hose fittings.....head north of my house and search the area that is the limit of my throwing arm....they are there!! lol
ronward
most likely will fit with a little persuasion...a little pushin and wigglin. If not, go with OMC replacement fitting
BigB9000
I recently bought one too.
Not thrilled with it.
bonz_d
As far as I know the oring that fits inside the female connector is still an available part. The male part that mounts to the motor, you better call 1st and take a pocket full of money with you. The one for a 1987 50hp is about $70.00 plus.
I agree, rebuild the existing original one with a new o-ring. the attwood units leak.
boobie
You can get by without that 0-ring and pin if you have to. The reason it's there is to keep the connector from dripping when you pull the fuel line off. The old models didn't have them.
how old are you talking. all the way back to 1954 that I have access to has the o-ring.
bonz_d
here I thought that the oring was to seal the male barb to the female connector so that they wouldn't leak.
boobie
The o-ring is in the female connector, not in the male on the older ones. The anti-drip ones with the pin on the end of them came out in the 80's. Meaning the male ones that are on the motor.
bonz_d
boobie whom or where did I ever say the oring was on the male barb?
The new ones drip as bad or worse than the old ones in my opinion.
boobie
Bonz, you're right. I must have read it wrong. And yes, the new ones drip as bad. Must be that o-ring in them.
bonz_d
I believe it more a case of poor craftsmanship in the molding process. Seams todays tolerances are more like + - 1/4" or yeah that's close enough.
I work maintenance and I find new parts that wont fit together all the time. It's really sad.
JohnnyRudeClassics
hi
thank you
Yeah,
there is OEM
and then there is
CEM ( China Equipment Manufacturer)
sized connectors
( I lol'd myself )
no, but seriously,
as long as the O-Ring is in great shape
I have not had a problem with any brand
of connector leaking.
( though I totally agree on having
Made in the USA is best )
Instead of having to drive 20+ miles to the nearest
BRP parts center and pay more than a buck and a
half each or ordering online for a buck and some
plus s/h, I go 1/2 mile to my local Home Depot and
get a pack of 10 for 2 bucks and some change.
Danco #78 - 7/16" OD x 1/4" ID x 3/32
good luck, let us know what ends up working out for you
