Re: War with lower unit
@MoodyBlue:
Keen eye on that seal. Though the inner one was still intact, the outer most seal was not! The spring and rubber lip of the seal literally fell out! I'm concerned about the crank where the outer seal would ride.
The end of that crankshaft is SHOT! That's where the 2 seals ride and that surface must be smooth or you'll loose crankcase pressure, it'll run poorly, and start sucking in water.
Merc sells a stainless "speedi-sleeve" that'll press over the end of the crank and provide a clean surface for the seals.
The crankshaft, as pitted as it is, should probably have a thin layer of JB Weld or epoxy to fill in the rust pits, and ensure the sleeve is retained on the shaft. Normally you could use some Loctite but the crank is too far gone for that, the Loctite wouldn't take a set.
Stuff some paper towels or shop rag into the block, to protect the crank bearing from foreign material, then wire brush/sand as much loose rust off the end of the crankshaft as you can. Smooth as best possible with medium-grit paper, degrease, and the JB/epoxy should make a good 'bed' for the sleeve, when installed. Clean off any excess JB/epoxy before it sets.
The P/N for the crankshaft wear sleeve is "86349A 1" (the "A" in front of the part # doesn't matter, and the space between the other "A" and "1" is intentional), and I've attached a pic with info on the sleeve.
HTH.........ed
