96Sailfish
Thread starter- Joined
- Jul 4, 2009
- 11
finally took the boat out today. its a 96 Sailfish with a 2 stroke 115 yahama. we got out of the idle zone after about 10 minutes or so. then i went to get up on plane and the boat was running great, then all the sudden the warning buzzer comes on, i panic and slow down put the boat in neutral and kill the motor. buzzer is still going off, turn all the power off and turn it back on. try to start, nothing, then she turns back over. head back to the dock and try to get on plane and the boat runs great, buzzer doesnt go off. so we turn back around. well a little later i try to get on plane again and the buzzer goes off. seems everytime i give it a little boost it will go off, but slower speeds its fine. by the end of the trip pulling almost back to the dock the motor starts sputtering a little, like it wasnt getting enough gas.
with this boat you mix the oil with the gas. it has been sitting for awhile before i bought it and when i test drove it, it didnt have this problem. the boat is peeing strong and its a steady stream.
any suggestions as to the problem?
