water circulation
noah4009
I have a 1971 55HP Chrysler. This may sound stupid, but where does the water exit from. At the bottom I see the 2 holes, just above prop, on the side, where the water enters. I see no exit hole. There is a hole about the size of a quarter near the top, back of the motor leg. Is this where the water should exit at if the system is cooling properly? The hole looks like black inside like it is some sort of exhaust. I do see the exhaust when it exits from the bottom under fin near the propeller. But Very very little exhaust from this hole on the motor leg. Is this hole on the motor leg a second exhaust and water exit spout also?
roscoe
Re: water circulation
water exits with exhaust, through both locations
noah4009
I started the motor and saw no water at all exiting from either. I even pull the short hose conneted to the thermostat and it was bone dry. It should be wet correct. I will replace the impeller, should I do anything else. Or is this just an impeller problem? Also top hole on motor leg had very very little exhaust.
Frank Acampora
The clear hose runs from the block to the head and should have water in it at all times the engine is running. --even with the thermostat closed.
If you are not getting water up to the block, then it is likely that you need to replace the impeller. That's a regular maintenance repair anyway--like windshield wipers or brakes on an auto--you don't expect them to last forever.
The hole in the upper leg is an "exhaust" IDLE RELIEF VENT. When you are running the engine deep in the water (like at idle or very slow speeds), it functions to relieve exhaust backpressure and improves the idle of the engine. That is why at idle you will see smoke exiting this hole. At idle, either in the water or on muffs, a bit of water will exit either in a slight stream or a spray while most will exit with the exhaust through the snout. Although it all comes from the same exit on the head, the water that exits through this hole serves to cool the midleg (and exhaust down-tube on larger engines) while the water that exits through the exhaust snout actually cools the exhaust and downtube and reduces exhaust volume.
At cruising speed, since the water pump is delivering so much more water, a steady stream usually will exit through this hole while again, the bulk of the water will exit with the exhaust through the snout.
noah4009
Frank
I've learned so much from you, But still need to learn alot more. (LOL) I ordered the impeller this past Saturday. I will try to get it repaired this weekend if the parts come in by then.
Thank You
xmos
Grt explanation Capt. Frank. I had the same question.
