water comming over the transom
ronnieray
Hi boaters!
I recently purchased an aluminum fish / ski boat. Its a 17 ft, 85" beam, walk through window, deep V type boat. It's paired with a 90 HP Merc ELPTO power trim engine.
When we get it up on plane, water comes back in over the transom. If i trim it ip high enough to stop the water from comming back in over the transom, then it begins to porpoise too much. I have an auto /float type bilge and I have to keep it always on in rough water cause the purpoising really gets out of control when the water is rough and I have to trim it down a bit, then the water comes in.
Why can't I trim it to prevent porpoising without taking water over the back?
Would getting the engine raised or lowered help?
There is a boarding ladder that just barely scratches the water when up on plane. Could this be contributing to the problem?
What if anything could I do to improve this situation or to seek help with it?
tashasdaddy
Re: water comming over the transom
that ladder is causing part of the problem, the other may the how the engine is mounted. if you continue a straight line out the back of the boat at the keel the AVplate (flat plate above the prop) should be 1 in above the line, and horizonal with the line. porpoising you may need to add some weight to the bow, if you can't work it out with the trim.
BF
by water coming in, I guess you mean that there is some splash back (?).. ditto that the ladder might be part of it... If your outboard puts up 2 splashes to the sides that go more or less straight up, that's usually an engine mounted too low I think. Do as td suggests and check out where the anti-ventilation plate is in relation to the hull... I'd guess you've got to go up a hole or two. Hopefully it's not a long shaft motor on a short (16") transom.
ronnieray
Thanks,
I removed the boarding ladder today and added 30 lb weight to the frontmost compartment. I will go try it out in a few days and see if I can get a better trim position.
tashasdaddy
did you check the alignment of the AV plate to the bottom?
kenmyfam
Interesting one, looking forward to a reply with some feedback.
