Water drops on spark plug
jhogue46140
Re: Water drops on spark plug
Well I am still baffled. I think the "screw boss" is what the throttle stop screw screws into. if I adjust the cam within an 8th of inch of it I cant get a spark unless timing is near 14-16. However if I adjust it like in the picture I can get timing right on 10. I have timing set and linkage and carbs move through the full range from throttle closed to wide open. I start he up and she runs ok and idles ok. I should still get a spark because the primary pickup can be adjusted back to same position as it is when I have current setup. Any thoughts? Doug
jhogue46140
Ok last post hopefully. After carefully studying posts and manual I went back and started from beginning. I was able to get throttle cam adjusted properly and timing set to proper specs. I had spark while I timed. I guess before I must not have had advance arm in proper position. Started her up and she sounds great. I didnt realize before after the other attempts she was running rough. Now she is smooth. Will be taking her out tomorrow fishing and give her a run around the lake.
My wife tells me I over analyze things. I think this might have been one of those times. I was making it more difficult than it really was. Oh well after all of the practice attempts I dont think this will be a procedure I will forget.
One last question though. You have mentioned a couple of times about having the advance module disconnected. I disconnected during timing procedure but have hooked it back up. What are the benefits of leaving it unhooked?Thanks Doug
jhogue46140
Took boat out today. She ran great. Hole shot was about 3-5 seconds. Not sure on top end or wot yet. The lake has a 20 mph limit. I did push her to 42 mph (about 3800 to 4000 rpm) once though. I hadn't even played with trimming her out or leaving the hotfoot down too long. Didn't want to get into trouble for speeding. It felt like she would do a lot more. Hopefully will be able to take her out to a lake without a speed limit in the next few weeks. I am curious to see how she does on top end.
I had noticed ever since I bought it last year that the water stream seemed to spurt and water pressure gauge jumped a little but now is a steady stream and pressure gauge us steady. Dealership I bought it from told me that this was normal. I know now it is not. I wonder now if it was starting to develop a problem then. Thanks for all of your help. Doug
