Water gathering in the bottom of refridgerator
crazy charlie
I own an energy effecient 15 year old Kenmore fridge.Water has been gathering in the bottom under the produce drawers.Thought it was the icemaker so I disconnected the water supply and still water gathers.Approx 32 ounces per 2-3 days.Time for a new fridge??Charlie
bigdee
Re: Water gathering in the bottom of refridgerator
Two possibilities are: 1;defrost drain is plugged 2; door gasket leaking allowing condensation to build up. What is the model #?
BaileysBoat
Been there. Frozen peas plugged the defrost drain. Easy fix.
crazy charlie
thanks guys,the model # is 9710313 Kenmore Coldspot.This is a frost free fridge.Where am I looking for this drain hole?? Charlie
Tim Frank
A full quart in just 2-3 day? That is a lot.
What is fridge configuration? Fridge only...freezer on top...side by side...etc.?
That's a lot of water for just a drain to be plugged....especially if it's not a freezer on top model.
If it IS a freezer on top layout, is there a layer of ice built up on the floor of the compartment? That may be blocking the drain...which is usually located behind a panel at the back of the freezer compartment.
For some pics and tips check www.repairclinic.com and VERY specific...http://www.justanswer.com/sip/Kenmo...PMT=b&JPNW=g&gclid=CNrJkJfog6wCFacEQAodSBGHNw
crazy charlie
Boy is this an oxymoron :D:D
Electric co gave me a rebate because of the energy rating.It is a freezer on top model and there probably is some ice on the freezer floor.I will start chipping away.Charlie
bigdee
Big thanks to you bigdee.I have to commend you.This is the absolute BEST reply I have ever seen posted in this entire forum.You could not have helped me more.You da man !! Charlie
You are very welcome.....I am just unemployed and very bored!!!
crazy charlie
Sounds like doing a little handyman work may help you be less bored until something comes along.Thanks again and good luck,Charlie
lakelover
I've had 2 Kenmores do this, and it was the clogged defrost drain. Crumbs, dust & debris get in there and the water can't drain out the tube. Both times it was a 4 or 6 screw removal, take the crud out & back together, easy fix.
