Mbaska1505
Thread starter- Joined
- Apr 18, 2022
- 6
I have a 2001 Volvo Penta 5.0 gl-a was fresh water boat but just took it out in salt water. Out on the water the boat got hot up to 200 degrees and the engine carpment was smoking because of the bellows. Shut the boat off got towed to the launch let the motor cool down slowly. The next day replaced the bellows and impeller but now I’m getting water in cylinders. Talked to mechanics and they said it sounds like risers and manifolds, took them apart and they aren’t rusty or corroded. Could the riser to manifold gasket go bad with the temp. I also did a compression test cylinder. HEAD GASKET OR RISER MANIFOLD GASKET
cylinder 1-145
#2-190
#3-150
#4-130
#5-145
#6-160
#7-165
#8-180
cylinder 1-145
#2-190
#3-150
#4-130
#5-145
#6-160
#7-165
#8-180
