Re: Water in my lower cylinder?? Johnson 9.5
My sense of pride is fighting with my cheapness on this motor. Head gasket is only $20 weather it needs it or not. The fight comes with where to stop. Every part for this motor is $10-20. Because it's a new to me motor I could easily do points, coils, plugs, wires, head gasket, carb kit and impeller.
When I add all that up I start thinking The other way...
Impeller if tell tale is weak.....
...spark is borderline on gap checker, jumps large gap but not every time. This is checked with motor running on one cylinder while checking spark on other...
...head gasket will show up on the water and I have both oars and a trolling motor.
...carb kit is the one thing I feel like there is no way to troubleshoot because I have no experience with this motor to know if it is lacking power. BUT, because I am cheap I will probably take the carb apart, clean with compressed air and "try" to reassemble before I give in and just buy the right kit.
I guess I'm just ranting about nothing at this point!?!?
Thanks for listening.
