Water in oil pan!!
So I have a mercruiser 140hp and water is getting in to the oil pan when I run it idk what it is does anyone have an idea
How can I fix that cuz I'm trying to go cheap and not so much work but the last guy said he ran it and then oil got in the oil he thinks head gasket and I have a motor that's a parts but it haves a cracked block
Ayuh,...... Now you've got 2 parts motors, with cracked blocks,.....
Isolate, 'n pressurize the block's coolin' passages, 'n listen,.....
Then follow the sound to the cracks,.....
My Guess is, the inside wall, opposite the drain plug,....
you fix it by getting a non-cracked block. basically buy a cheap rotten bayliner hull with the 3.0 in it and scrap the boat hull, keeping the motor.
I got another but now it's not starting it haves spark and gas still nothing every 25 secs it backfires the back to the normal cranking
I scraped the other motors and starter is good. New plugs and idk if it haves a kill switch 🤔me and the mec are lost thanks to brainerd mn they don't know anything about boats same as me
I never touch timing other then water pump this is all I did to it
OK and yes it's my sumer house I use it to rebuild stuff and **** around 🙃 my girl helped with most of it sadly
Grub54891
Good Marine mechanics are getting harder to find. Sound's like your mechanic needs some schooling. Spark, compression, fuel. Just have to know when it's all supposed to happen in the right order.
