Abductedkris
- Joined
- Jun 20, 2009
- 5
Ok guys here's another question. First of all I have a 1956 evinrude bigtwin 30HP model 25022. This motor works on a pressure tank setup. I have checked the coils and points. I have inspected the impeller and repaired impeller housing. I had it running but EXTREMELY rich. After about 10 minutes of feathering the throttle to keep it going the water in the barrell was completely black. So note that it was running. Then I did a carb rebuild with a new kit and I think I did a good job with that (Poor directions come with kits). So yeah, after the carb rebuild I tried again, first pull I got a sputter then Nothing after that. I took a gas siphon and puled some gas out of the tank into a spray bottle, and wuddya know, two layers of colors. So I drain the float bowl into a seperate bottle, and wuddya know, two seperate colors. Just to be sure I took some gas from my weedwhaker can and put it in a cup and added some water, and wuddya know looks like the other two. I had to be sure because I havent ran into this problem before.
So I had the motor running, then I did a carb rebuild. I bought the motor and tank on fathers day and can't remember if anything was in the can before I added gas. But since water sits on the bottom I would think it would'nt have ran at all to begin with. So my dillema. I'm wondering if it's possible that the pressure system for the tank is somehow pumping water into the tank too. I'm not too familiar with these and I'd hate to waste gas by trying again without knowing. I'm posting a pic with this to show how much water was in the tank with a gallon of gas. To me it seems a bit more that condensation. I just want to know what could cause this much water short of pouring it in the tank myself.
Thanks guys Kris
Thanks guys Kris
